This event is triggered when information received from the DOS Protect kernel module does not match the information expected by the DOS Protect application.
This could happen if the version of the kernel module is not in line with the version of the DOS Protect application. As we currently only support full system upgrade this should not be a problem. If this problem is not solved by a system reboot (re-initialization of the kernel), get in touch with the Extreme Networks Technical Support organization (who will need to get in touch with Engineering after replication).
Warning
Read size %rc% not equal to %strct% size %size%
| Name | Type |
| rc | uInt |
| size | uInt |
| strct | String |
